- Naples Florida
- SX
Now I'm confused!
Now I'm confused!
I think the water you are talking about in the cleanout is absolutely normal. 100% of the time I have to uncork the plugs by dipping my hand in water.I haven't had a problem yet, but the other day after taking the boat out of the water I has water almost to the top of the clean out port.
once I took out the plug, which seemed properly seated, it drained out but left me wondering.
In any case, the whole ride out was without a hitch, never any indication of problems. I tried to remember if I had been in any situation where the water could have gotten that high up the stern, but couldn't really think of anything.
I know I always double check both the drains and the plug, so it was on properly when launched.
Mystery...
So your saying you had a good dayOut on the water less than 10 minutes this morning, bost running fine, stopped to talk to my buddy in another boat. As I gassed it from there, felt something was wrong, thought I may have sucked something up. Stepped onto the rear to open the hatch, noticed stern was riding low. Port side plug was unseated, Tru locks did their job, put it back in, checked engine compartment, water half way up engines! Bilge was pumping, back to dock we go. Checked again, water dropped dramatically, no sign of any other issues. Great rest of the day, no water in engine compartment, all good. Then about 15 miles from home, I lose a bearing on the rear driver side axle! Luckily looks ok, should be fixed before I leave for Lake Anna on Saturday! Top it off, my buddy broke a bunk board on his trailer, just bought the boat/trailer last week!
Any aftermarket lock should totally prevent the plug from coming loose or blowing out under pressure. And with EZ locks, you can't install them wrong if you look for the tips touching when installed. Then if the internal lock fails, it stays seated and does not release or blow. As a matter of fact, you must then relock the plug to unlock the ez lock just to get them out. While they may protect the hatch, I believe that nerf footballs increase your chance of a flood and engine damage, so I don't use them or recommend them. EZ Locks are the cheapest and most fail safe insurance you can buy. I wouldn't have a yamaha without them. Just my personal opinions.
What is your thought about the Tru Locks vs. the EZ- Lock's? I know both are valued sponsor members, but just looking for an opinion on the operation of one vs. the other.
