Boat length
Philip
Long Island NY
does anyone know the actual length of boat from bow to transom- not including platform? Trying to order an air dock and need measurement. I'm assuming it's prob 2ft , so around 21.6 length but defer if someone already knows.
Ronnie
SF Bay Area
I think you should specify the year and model of your boat. If you just need to make sure that the hull is supported end to end I'd specify that as well since the swim platforms may /should have different dimensions and start on different parts of the hull for different models. Also remember that the 2015 240s are 6" longer than the older models.
Philip
Long Island NY
2011. 242 limited s
Hull needs to be supported. And couple different models boat length is measured from end of hull/transom to bow, I know boat is 23.6 but that's tip to tip
