Jeff L24
- 195S
My 2021 Yamaha 195S handles very well with Cobra AK-19 Deluxe fins under NMW and cruising speeds (25ish). I did notice at pure idle the boat tries to turn left regardless of my steering input. And at higher speeds (35+) I have to turn the wheel slightly right to maintain a straight heading, as the boat is slowly pulling left. I have amazing control at NWM1 but at forward idle (first detent) it drifts left and is hard to control with even the slightest wind. At pure idle it spins left in an obvious way. I never used the boat before installing the Cobra fins so I can't comment on before & after. I've checked the jet nozzle and fins with the wheel straight and everything looks normally aligned. Is this a common thing with single engine Yamahas (possibly similar to prop walk in a sailboat)? Otherwise the boat is amazing and couldn't be happier. Docking and trailering using NWM1 is super easy, but I'm afraid to ever be in pure neutral because I lose control immediately.
