rayg1022
What I found with mine is that the bow bounces around when traveling if it's not supported by the roller. Still may be safe, I don't know. But it bounces.Is it nessasary to bring the boat all the way up and past the roller on the trailer or can there be a cap between the too if its strapped and chained?
As tight as possible, many use a "5mph hard stop maneuver" to push the boat forward on the trailer. Before getting out on a highway. I do.Is it necessary to bring the boat all the way up and past the roller on the trailer or can there be a cap between the too if its strapped and chained?
It will(almost) always do that as the trailer flexes. A short "5mph hard stop" off the ramp will tack her nice onto the roller, then tighten the stern tie downs. After that the boat should not move on the treilr an the tie downs should not get any slack, no matter how far the tow.Got it. We took the boat out yesterday and when cranking the boat to trailer all the way to the roller when I pulled out for some reason the boat shifted back off the roller why is that when it was tight to began with?
If you are launching or retrieving and you have trailer guide poles - no, they can jam w/a bumper.Is it okay to leave your dock bumpers attached to your outside of your boat at all times?
The gap happens after you pull the boat out of the water because of the angle of the trailer on the ramp in relation to the angle of the boat floating on the water. The more the angle the more the gap
I’m not hip to what ^^ means but I think we are saying the same thing. The greater the angle delta between the trailer bunk plane and the resting plane of the hull on the trailer the greater the gap between the bow and the roller as the two planes become parallel when exiting the water on the ramp.This ^^. The steeper the ramp the more exaggerated this effect is.
LOL - I'm not hip either - was just "pointing" to your quote. i.e. agreeing with you.I’m not hip to what ^^ means but I think we are saying the same thing. The greater the angle delta between the trailer bunk plane and the resting plane of the hull on the trailer the greater the gap between the bow and the roller as the two planes become parallel when exiting the water on the ramp.
