Ericd
- Illinois/Florida
- FSH Sport
Installed a set of BoatBuckles on my 210 FSH. Ordered the extra brackets because the trailer mounting points wouldn’t allow the straps to be straight. I also replaced the 1” 1/2” bolts that came with the buckles with 1” stainless steel after having to grind one of oem bolts off because the nut froze on bolt and wouldn’t move. Probably a quality issue, but the 1 1/2” bolt was in a pretty tight area and the 1” fit a lot better.
There a little flex in the extra Buckle bracket, but I don’t think it will be an issue. The ratchet tightening and easy release is wonderful compared to the Yamaha suppoed straps.
