BOW TABLE MOUNT YAMAHA 252 series
Vinny Dip
has anyone tried installing a table mount on the bow of the 252 series?
Txbred
252SE
I have not done it but I've seen it done. It's the same set up as the one on the stern. I installed one where the battery switches are.
deadpool4514
252S
I would be very interested to see pictures of this. Also where did you get the hardware.
biffdotorg
Pelican Rapids, MN
If you wanted to use the leg provided with the table, you could just use the bracket in the parts fiche. Otherwise, a floor mount could be used with a new table leg.
Cambo
Long Island
@HailMary makes table legs and sells the table base attachments as well. Just eye it up and order a new table when you attache the mounts you will have a lot of flexibility in the position
I used this table
Grkspeed17
252SD
Anyone done this? I have a 23’ 252SD and want to add a mount at bow to put the table. Be nice if someone has a how to or some pics of the process. I always get nervous drilling holes in this boat without knowing exactly what I’m doing.
Cambo
Long Island
Didn't mount one in the bow but did relocate the swim platform remote and ordered a new bracket. The factory yamha has a back plate so that when the table leg is inserted the table is level but a few plastic washers inserted on the lower bolt through areas positioned the plate to the correct alignment.
PJFan1977
Rochester, NY
252S
I'd be interested in this as well. I have a grill mount that I use in the existing bracket so no place to set up the table while cooking. Would be great so the kids have a surface other than my clean seats to spill their food on!
