Ottoman711
- Baja
- Other
- Other
Hi guys, I'm new.
Recently bought a 95 Baja blast with a Merc 120hp engine and I'm having some issues. Finally got it in the water and the boat wouldn't barely move. So I gave it more and it felt like a slipping clutch. It wasn't the engine causing this, could it be a bad seal on the propeller? Also I'm a bit confused about a line that spits water from the top of the engine down into the hole. I assume it's cooling the engine but where should it be spitting out?
