Can You Confirm Any of These Numbers?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Last year, I did most of these by "feel", but I'd like to get the numbers correct ideally. Can anyone confirm any of these? I looked through the manuals I do have and couldn't confirm these with what I have but found them across various forums/You Tube videos. Obviously some I can measure, but still nice to know what "should" be in there theoretically.
- Spark plug torque: 17 ft-lbs
- Coolant drain plug torque: 73 in-lbs
- Engine coolant amount: ??? (about to do this for the first time, how much is needed?)
- Engine oil amount: ~ 3 quarts
- Vacuum pump suction tube length (to go into engine dip stick): 17.75"
If you can confirm any of these (or have a different number), please post here. Merci.
