It's not primarily a surf boat but it can be made to surf.Looking at possibly getting a 2010 Yamaha 242, and wanted to see if anyone had success surfing behind one. If so, what modifications did you do?
It is possible, but it can be challenging to go ropeless, and if you do the pocket is so small you don't really do a whole lot of room to play. Boats compatible with the new WakeBooster are getting better results, but even that has been reported to be better with additional ballast. The real key is to get as much weight as you can in the back corner and get the boat to list surf side.Thanks for the info. Is it possible to surf with only internal ballast and the wake shaping device? Wake doesn’t have to be perfect and I don’t mind having to hold onto the rope a little.
Short answer: no.Thanks for the info. Is it possible to surf with only internal ballast and the wake shaping device?
Just to clarify, a 242LS has no internal/stock ballast. But if you are referring to internal ballast, as in the ski locker, that does help, but not like the custom transom bag. You can rope surf behind it with plenty of friends stacked on one side of the boat towards the rear. Just don't expect a wave like you see from these other custom setups.Thanks for the info. Is it possible to surf with only internal ballast and the wake shaping device? Wake doesn’t have to be perfect and I don’t mind having to hold onto the rope a little.
