SOLD CANDOCK Floating Lift/Boat Dock
Water Girl
Doylestown, PA
IMG_7299.JPG For sale is my Candock boat lift for $5300.
I'm near Philly, PA, dock will come apart for transport. Can also be reconfigured and used as two waverunner ports as well. Possibilities are endless with this and the company is great to deal with if you need any additional parts.
Has air tank in rear that will lift back end of boat out of water for easy drive on/drive off loading. No mechanical parts to break so this lift will last practically forever. New they run around 15k or so. Thanks!!
0627Devildog
Classifieds Moderator
Acworth, G.A.
https://flic.kr/p/XNbRjE
FYI - The link appears broken. . . . pic is not showing.
Water Girl
Doylestown, PA
Should hopefully be corrected now. Thanks!!
0627Devildog
Acworth, G.A.
Water Girl
Doylestown, PA
Ok. As it sits now it is 12.7 foot across the front at widest part. Center section (where most of the boat sits) is 9.5 feet across (which is all it needs to function)
Length from front to back is 23.75 feet. Keep in mind that I have the front part wider due to my own preference to set up chairs and sit on the front. The extra rows on either side can be removed , as well as a row or two in the front to make it shorter. This thing can be built any way you want. I also have 6 extra cubes and many extra connecting pins and parts
Ron Reinert
What size boat do you have on it ? Would a yamaha 242 fit?
