Candoo reading of system
Stang7tl
195 Open ID
Anyone got run logs of what the candoo ready and etc. I’m looking for someone that can let me know if the TAS and TPS are matched up or what? My boat is capping out at 6900
It was under warranty so I took in but got screwed by the shops and now BRP
But here is the list of checks and work already
New plugs
Fresh gas
Replace tank filter and fuel pump
Pump inspection
Intercooler test
Manifold test
Boost hose checked
MAP sensor replaced
Candoo fault scan
the boat runs great starts right up gets on plan quick just won’t go over 6900 rpm.
I bought candoo and I have TPS going to 99% at wot and TAS 897%
That is the only od thing I see
Stang7tl
195 Open ID
Intake pressure 20ish
