Bruggar709
- SX
What brand epoxy did you use and how lond if a process is it? I have never did an epoxy repair before so looking for a little guidance.Unscrew and fill the hole. Some use 3m 5,200. I used white epoxy.
May have to try this, thanksI used this. Just used a flat toothpick and level with finger. Wiped finger with acetone rag inbetween. Can't even see it. https://www.amazon.com/J-B-Weld-50172-MarineWeld-Adhesive/dp/B00R2CDVIW/ref=sr_1_5?crid=1LSSP20OOXM02&keywords=epoxy+resin+syringe+white&qid=1658335855&s=industrial&sprefix=epoxy+resin+syringe+white,industrial,76&sr=1-5&th=1
Snaps wouldn't line up. Remove, repairThe snaps suck to step on and the grey vinyl mats that came with my boat are too damn hot to walk on after a few minutes of being in the sun.
I figured it may be worth it to keep the snaps in case I wanted to get the sea dek and snap it in rather than trying to glue it. Anyone have any thoughts on that?
Is this the color you used,I had a couple other nicks on the outside of the boat I wanted to touch up, so used Spectrum gelcoat repair paste. Perfect color match.
thanks for your helpyep.. mine is a 2018 AR195 but believe the white has been the same for many years.
Spectrum Color Yamaha Boat White Coat 5 04-21 Boat Gel Coat
SKU: IB00251488
MFG SKU: 7018-K
