Tkline
- SX
We just purchased a 2014 Yamaha SX 190 Yamaha, being sold on consignment from a marina in MA, about 2 hrs away from us. The marina’s mechanics told us everything was perfect with the boat. We have been out for three one-hour rides over the past two weekends on the Hudson River. On the second trip, we started the boat and noticed a lot more vibration. We moved out of the slip to get gas and there was very little power and suddenly the engine started to smoke and the engine temp,alarm sounded. We shut the boat off, tied up, opened up the clean out port, and pulled out several large sticks thicker than my finger. We started the boat back up amd took it for a shake down and everything seemed fine. On our third trip out, after running the boat for about 45 minutes at 30 mph, my son was driving and opened up the throttle to pass a larger boat. The wake was very large and as we came over it, I think he pulled the throttle all the way back past neutral and into reverse.The motor stalled. We restarted the boat and continued on. Again, at about 30 mph, in about 10 minutes, the boat started surging and we slowed down and then noticed smoke. We opened The clean out port and I did not feel any sticks. We opened the hatch to check the oil and there was none on the dipstick. But in the cap there was a water emulsion, like mayonnaise. We called Sea Tow and we were towed back in. That is our situation now. I assume the oil is emulsified and sitting in the very bottom of the engine, but not registering on the dipstick. I’m wondering if anyone knows why this happened? Could we have blown a head gasket with the impeller being stuck by sticks, or is it possible for the engine to aspirate water when running wide-open and suddenly shifting into reverse? since i think the first case will lead to a new engine, i am hoping it is the second case and we can just have the engine cleaned out. I am hoping this will give us some information to give to the mechanics and hopefully we don’t need a brand new engine In a boat we have run for 3 hours. Thank you, ahead of time for your help and insight.
