giantsmotox
Hey there everyone, long time lurker and first time poster here on the forum hoping that someone can assist me with a sudden issue I am having with my boat. I have had my 2014 AR190 for 2 years now as the second owner, and it has been flawless with 240 hours on the engine at this point. I always run in salt or brackish water in and around the Chesapeake Bay. As I was out pulling a wakeboarder yesterday, the boat suddenly started making a grinding noise and vibrating, and lost all thrust above 5k RPM. The feeling and sound was similar to cavitation when coming out of the hole pulling someone heavy on a tube or wakeboard, but did not improve as it usually does after a second or two. We limped the boat back to the dock, and were able to maintain 4k without much noise or vibrating. The engine will rev out completely its max RPM, however the boat will not move past 10MPH. The clean-out port and intake were completely clear as well. Upon arriving at the dock I noticed that the bilge was pumping water which was unusual, and upon further inspection I saw that there was a small leak coming from what appears to be the bottom right bolt where the transom meets the intermediate bearing assembly. The leak appears to occur when the engine is off and at low RPMs, however I did not verify if it was leaking at higher RPMS. I have attached a picture and highlighted where the leak is coming from. This leak is only coming from this singular area, and there is no water coming in bilaterally or from other places in the assembly. I have family visiting in 2 weeks for a boat-filled vacation, and will do everything in my power to get this back up and running prior to that. Does this lead one to believe that I blew out sealant and that the area around the bearing assembly can be patched to remove the cavitation and prevent leaking, or is this generally caused by blown out bearings and seals and a new assembly is in order? Thanks in advance for all of the help! - Rob
