downchild21
- SX
Hello, I have a 06 sx210 that i'm fixing up. The port side motor is stuck in limp mode . In short, the code clears if you move the cables to the Starboard fuse assembly . I cleaned the port connectors and the code also cleared. After 10 minutes on the water , the code is back. The overall fuse assembly is back ordered. Is there a specific relay in the fuse assembly that would cause this code in the throttle system ? Thanks in advance !
