Steve73
- Downingtown, PA
2018 AR190 has issues getting through 7mph-17mph range. It will go through but I have to be gentle on the throttle otherwise it gives a sound pitch change that sounds like air in the jet and feels like I’m spinning my wheels. I believe this is the symptoms of cavitation right? More weight on board slower I have to go. Had 6 adults on board and I could barely get through it to get on plane. Took a good full minute or two of ever so slowly increasing the throttle through 7mph to 17mph. Eventually got on plane. Here’s a bunch of pictures. Anyone see anything that needs caulked or any issues with my impeller? I also find water has been getting in the bilge area when I spend time at speed on plane. Not sure if related. I think it’s water getting past the clean out plug but going to use a go pro next time out to figure that out.
Thanks in advance.
Thanks in advance.
