Chaparral 243 Vortex - First Service
Kparis14
Jacksonville, FL
Chaparral
VRX
Has anyone on the board done the first service on their boat? I have 26 hours and need to do the first oil change.
My boat is a 2015 with the twin 250 Rotax engines.
Was quoted an obscene amount by dealer. I just ordered an oil extractor from Amazon, plan to pick up 2 Seadoo oil change kits at local dealer (oil, filters and new O rings) and do the service myself.
I found a great video online that walks you through the entire process.
Has anyone done this?? Just curious.
veedubtek
Punta Gorda, FL
Scout
I've done it on my (old) Seadoo with the twin 215's. Make sure you have an inverted torx socket for the oil filters. Otherwise, very easy and straightforward.
Kparis14
Jacksonville, FL
Chaparral
VRX
Thank you- any idea what size Torx socket?
Vandyman
Brentwood, TN
Chaparral
VRX
you can change the oil and filters fairly easily, but I believe the computer will need to be reset as it is based on hours. I finally let a dealer do it... cost me about $300 as I recall for both engines. If it is your first service they also check hoses and such to make sure all is still tight. Regardless of who changes the oil, make sure to not overfill, and do not use full synthetic. I may invest in the CandooPro as I also have a pair of Seadoo jet skis that I do service myself.
Kparis14
Jacksonville, FL
Chaparral
VRX
Thank you. I was told the dealer would need to reset the computer. Problem is I don't have anyone close by. My dealer offered to reset it next time they're in the area
I plan to change the oil on my own. A local shop quoted $1000 for two engines which is obscene.
swatski
North Caldwell, NJ
That is obscene. I thought Yamaha was expensive at $400 (200 per engine)...
veedubtek
Punta Gorda, FL
Scout
Inverted torx. I wanna say E8 or E10, but don't quote me on that.
Vandyman
Brentwood, TN
Chaparral
VRX
That is insane!! Is there a Seadoo dealership nearby? I found a local non-Chap boat dealer but they sell Seadoo jet skis and was able to reset the computer codes. My VRX was the first they serviced but think they have since seen another.
Kparis14
Jacksonville, FL
Chaparral
VRX
Thanks, I have a plan. My local seadoo dealer is where I'm getting my oil change supplies. I will inquire about them reseting the computer for me (requires them coming out to my marina). If not, the dealer where I bought my boat has offered to swing by when he is in the area to reset it for me- incredible service!!!
BobJohnson
Highland Park, il
Chaparral
VR
torx 10 for the oil filter. whole process is very simple. I did my 2 engines in the spring and the only issue I had was trying to tell when I had the right amount of oil in. Idea is to put in what comes out. Measure on dip. Run engine to distribute oil through filter, measure again. But, that oil is so light in color it was tough to see where the oil was hitting the stick. I knew I was in the ball park and after running the engines a little more, the oil darkened enough to see I was OK. grand is crazy for 2 oil changes.
blackhawkpilot
Enterprise, AL
Chaparral
VRX
I bought mine with 23 hours on it and the first service was already done. What are the service intervals? I can't find them anywhere. Once again...the owner's manual is SEVERELY lacking.
Kparis14
Jacksonville, FL
Chaparral
VRX
This forum is so awesome- power of information sharing. Thank you all for the great comments and guidance. I just purchased 2 (I have dual engines) oil change kits (1 gallon of oil, filter and O-rings) for $65 each from local Seadoo dealership. I ordered the oil extractor from Amazon for $50 so all in my parts were: $180. I watched an excellent step by step video and will tackle this on Saturday morning at my marina.
Update on Service Cost-
I did want to clarify the dealer who quoted me $950 for the 2 engine oil change change had an typo/error in their estimate. The new total is in about $200 less which is still way too expensive for me.
Open Question-
Once the oil changes are done has anyone found a manual way to reset the computer? If not, I can swing by local Scarab dealer (also rotax engines) and have them hook up their computer to reset the engines for me.
Kparis14
Jacksonville, FL
Chaparral
VRX
Did my first oil change today on my Vortex with 27 hours. The first engine took me a little longer as I was getting use to process. The second engine was done in half the time. All in 2 hours. This was so simple- that I will always change my own oil from now on. Now just need to have my computer reset to eliminate the Maintenance warning on the screen.
Feedback- I wish our dipsticks showed the oil level a bit more. I found it difficult to spot the level with new (clean/clear) oil. Oh well.....
Bryan mazanec
Tampa FL
Chaparral
VRX
I paid 475 for my first 10 hour service. They came to my marina and the mechanic is BRP certified.
Bryan mazanec
Tampa FL
Chaparral
VRX
My mechanic said 10 hours and then again at 50 and every 50 after or every season
Yan Masse
Trois-Rivieres, QC, Canada
HO Impulse
Open Question-
You can try Candoo Pro to
reset the computer.
For the price, on my scarab it was 200$ at the dealer for a single 250 SC
Ronnie
SF Bay Area
Wow, I thought only my local YAmaha dealer gouged customers for performing the first service (primarily an oil and filter change) on their boats, $800 last time this came up about 2 or 3 years ago now. Way to expensive for me.
I hope you all find a way to a manually reset your maintenance warning lights. @Scarabtech and / or @ScarabMike may have some insight here in that I recall reading one of their posts which described how to reset a warning light on a scarab jet boat with brp engines.
Just curious, why do you need an inverted torx socket for the oil filters? Are they held in place with a supplemental screw or bracket?
Jeff Cox
Lewes, DE
Chaparral
VRX
Just had my 25 hour service from my dealer. 299.99. Boat came back with every connection lubricated, tower, everything on trailer etc...I felt price very fair for 223 with twin 250's.
blackhawkpilot
Enterprise, AL
Chaparral
VRX
Interesting. My dealer said my next service isn't due until 120 hours. Also...I picked it up on Saturday after getting the O2 sensor replaced and a new steering cable. The dealer cleared the P0113A code, but I now have a "Check Engine" (starboard) fault and "Maintenance Required" on both engines. Frustrating as my dealer is 2 hours away. I may take it to a different place next time.
Bryan mazanec
Tampa FL
Chaparral
VRX
How many hours are on your engines?
