Chapparal Vortex VRX - LOST REVERSE
kslocum1
Traverse City, MI
Chaparral
VRX
All electronics seem fine. Motors run as they should and no other issues. There is not an eReverse Module error. I believe it’s a physical/mechanical issue related to the IBR system. There is fluid/oily liquid under the motors (not dirty and looks yellowish on a rag that appeared for the first time we lost reverse. Trying to figure out if the system that lowers the buckets reverse buckets is hydraulic? Thanks
Thanks. The Dealer finally figured it out. The Dealer installed SHIFT CABL (first repair$897.47) . First trip out rod bent again. The dealer contact BRP helpdesk and they said that the needed to replace the actuator ($800ish part) and replace the cable for a second time (second repair totaled $1,998.40).
