Clamp for water towing question redux
Eldonfredo
195S
I swear on my wake tower I’ve read every thread on this topic. I am slow I guess.
2022 195s.
I’m mostly confused because the “y” clamp most posts reference I cannot see or find. So the images show my best guess. I marked the hose I think I should clamp with orange tape. One picture is wide view top down for context, the second image is slightly more zoomed in to prove there is no “ y “ clamp. Or there is and I’m a lunkhead.
Following
The "y" is a fitting, not a clamp, that splits the water intake to the engine. One branch of the Y is from the hose connection (red hose) to run on the garden hose and the other is from the jetpump water inlet screen. The clamp part is where to clamp that water line or install a shut off valve if you are ever towed at greater than 5 mph. That orange tape you put on the hose is not the hose to clamp unless the design has changed. This is it. I marked with orange where hose clamp pliers or tow valve would be installed.
The hose you marked in orange IS the correct hose... The "y" fitting you are looking for is in the area behind that wall/under the clean out hatch area. The new models have the flush port in the back of the boat instead of inside the cockpit so you very rarely see the fitting inside the engine compartment anymore.
also,
if you're installing a clamp for emergency towing, you can do it at the orange tape, anywhere before the cooling water enters a component,
if you're installing clamps for flushing and want to direct all water into the engine, install the clamp on the raw water intake line from the jet before it connects to the Y fitting, if you flush without a clamp you loose a lot of hose water that backflows out the inlet at the jet,
This is the best option if you are going to go through the trouble. It also allows you to flush while on the water without contamination of salt water.
