Clarion CMD7 w/ amp - fading help
RightStuff
Twin Cities, Minnesota
Moomba
Hey all... So I finished my amp/speaker install and was playing around with the Clarion head unit to tweak the sound a bit. In doing so I tried fading the sound front to back and ran into an issue in doing so and couldn't get it to work as I thought it should...
My setup:
Clarion CMD7 HU, 6 channel amp driving 6 speakers (1 channel each), I also double checked my speaker wires plugged into the amp to make sure the bow 2 were on 1/2, the in cabin on channels 4-6. The front RCAs from the HU are hooked up to channel 1/2 on the amp, then using a RCA splitter I hooked up the rear ('no fader') RCAs to the amp on channels 3/4 and 5/6 (2 RCA outs split to 4 RCAs to the amp). No sub in my setup either.
Question:
What I would like to do is fade the front 2 speakers and the rear 4. By doing just that I thought it would fade rear to front, but by fading to the rear I loose all sound on the 4 back speakers. I tried playing with the fading option (goes from -6 to +6) and that worked to get sound to the rear channels, but the fading didn't seem to work either. So what settings are others using that have an amp driving their cabin speakers?
For now I just have the amp in 2 channel mode, so the signal from the HU just goes to all 6 channels, and that'll be fine for now. Just really confused me when I couldn't get the fading to work and the manual for the Clarion was useless with regard to the settings.
Seems to me you would need to run a set of RCAs from the REAR out on the headunit for it to fade.
EDIT - I think you can set the REAR output to either non fading subwoofer or rear. Looking online I see it offers a Front output and a switchable rear/subwoofer. Look in your Menu on the headunit and see if that is an option.
There are 3 pairs of RCAs coming out of the back.
  • Aux input mounted to the dash
  • Front (L/R)
  • Rear/no fader (L/R)
There is a 'no fader' volume options that I set to +6 and got sound out of the rear speakers, but fading front to back still didn't do what I kind of expected. The other is a Rear/N-F option (Rear or No Fader values) and that I would think should be set to "Rear" to make that last set behave like the rear channels, right? So with those options set like that I tried fading the sound front to all rear it was not right, the mids would cut out and the front and rear speakers would have sound. Just was odd, so I'm hoping someone else has figured that out.
For now I just have it running in 2 channel mode, which works fine, just no option to fade sound to just the front or rear speakers.
I don't know if this will help, not knowing the amp settings, but try running the front RCA's to channel 1/2 on the amp. Run the rear RCA's to channels 3/4 on the amp. In your amp settings, let the rear RCA's provide the signal to the amp for channels 3/4 and 5/6. Then when you fade, you will get either the bow, or the cockpit, but you don't have 3 zones whether you split the rear or not and you don't need to split the rear signal, the amp can sort it out. You only have a front and rear signal from the amp. Edit...meant to say you only have front and rear signal from the HU.
Man, if I find a way to have the 3/4 input power the 5/6 as well as the 3/4 on my amp, I'm gonna be pissed. Bought parts and everything to split that, after reading for a long time on how to do that. I hope it is not possible on all amps.
AAARRRGHHHHH! I think I just figured out how to do it. 'Summed' setting instead of 'Discrete'. That is what it is called on my amp to do what @txav8r describes.
Now I gotta rewire things.
