cleaning carpet?
Ric Moseley
Cedar Creek Lake (near Malakoff, Texas)
Does anyone know the best way to clean the carpet? Mine has mold (see picture) on the bottom and top in certain places. Is there a good spray that wont change the color of the carpet? Can I put it in the washing machine? Pressure washer? Ideas?
I used to remove my carpets from the boat and use a regular carpet cleaner. It works great. When I had carpet I took it out of the boat after every outing and hung it out to dry so it did not mold. In the long run I would suggest installing SeaDek. All of those problems go away. Just spray it out and you are good to go!
I pressure wash my carpet. Try some non-bleach based mold cleaner from your favorite big-box home improvement retailer and the pressure washer.
