axiomkc
- Shawnee, KS
I have Cobra Magnum AK series steering fins + fangs on my AR240 which I've owned for over a year with no issues -- the Previous owner installed.
All of the sudden the Reverse Bucket on the Port side will not go down. Once I pulled it up on the lift to investigate, the bucket appears to be hitting the bolt in the picture attached. Everything seems to be tight/snug, so wondering what you guys would recommend adjusting or where to look for the issue. The Starboard side is fine and I can see there is about an 1/8 inch to 1/4 inch clearance on the bucket when it comes down in reverse, but this port side is immediately being blocked by the bolt now. At first glance nothing seems to have been bent or jammed, but will be taking a deeper look when I'm back out tomorrow. Was hoping for some insight before heading out.
Appreciate the help.
