@Evil Sports Basically, the homes on Cape Coral are (1) off the water, (2) on a fresh water canal or lake, (3) gulf access canals--most are "direct access" with no locks, some are "sail boat access" that have no bridges to go under--and the most expensive category are (4) those facing the river. As an example, if you buy a house off the water for $150k, figure to be on a fresh water canal about $250K, to be on a gulf access canal $400K, and to be on the river $700K for the equivalent home. When I was looking for a place to buy I decided to buy on a fresh water canal instead of a gulf access and save a couple of hundred thousand dollars. I just keep my main boat at the indoor marina for a couple of hundred dollars a month and drive about 12-15 minutes when I want to get to the marina. However, a lot of people want to be able to go out their back door, get in their boat, and take off.
When looking at gulf access canals one thing you have to be careful of here is the distance to travel from your home to open water. The entire canal system here is a "no wake" zone so if you have to travel 2-3 miles in a canal to get to open water, and then back again, you will be spending a lot of time in your boat. There are many homes that are much closer to open water but they will cost a bit more. (That was another reason I liked the indoor marina since it is only about 10 minutes to open water.)
I first came here looking at houses in 2011 and met a real estate agent who helped me over the next year before I made a final purchase. She was very good, exceptionally patient, and if she didn't know something she told me so instead of acting like she knew everything. I will give you the link to her website where you can search through the properties to see what is available. The zip codes I would recommend to search would be 33904, 33914, and 33990--not sure if you can zero-in on those codes or not on her site. There are other cities close to Cape Coral you may want to research but they have a completely different lifestyle and atmosphere. For example, Cape Coral has a lot of restrictions for homeowners--no trailers, RVs, commercial vehicles, or boats are allowed to be parked in the driveways. You can park your boat on a trailer on the side of your house in the back, but not in the front. If you go to any of the adjacent cities you will see everything parked in the driveways--some people don't mind that but I wanted a less junky area to live in.
I took a few videos today in the boat but I'm having problems getting them to look decent on YouTube--if I can resolve this problem I will post them later so you can see a few of the canal homes we passed by today. In the meantime, if you want to take a look at my real estate agent's website to search some properties, this is the link:
DreamHomeQuest
