Contact Info
RobbieO
Sacramento River Delta
212SE
jetboatsupply
Thanks. You already have my first order! I’m liking the website. Good luck!
No, thank you! Your order will be in the mail first thing tomorrow morning :cool:
JASmith
Minnesota
Just ordered your tow valves. I assume they are universal and work on any of the engine types? Intended to use on my 210 FSH, twin TR-1's.
Thanks!
jetboatsupply
Thanks!
They will pretty much work with any 4-stroke jet propulsion engine but we've personally only used them on 1.8's. If for some reason they do not fit, we would be more than happy to get you a size that does work for the TR-1 engines or offer a full refund.
We appreciate your business and will have your order out shortly!
RobbieO
212SE
I have not seen the stainless valves on your website yet.....
RobbieO
212SE
So is the lever continuous throw, or does it lock at 45 degrees?
jetboatsupply
It locks at a quarter-turn (90 degrees), similar to the Original Tow Valve you had purchased. The max PSI of the ball valve is about 900PSI also, which is far far far more than it will ever see being used as a tow valve.
RobbieO
212SE
My bad, yes, 90 degrees...
