buckbuck
- Texas
- X
I have been wondering about what kind of water pressures are developed by the jet pump for cooling the exhaust and engine. My curiosity peaked after OperationROL had trouble with his boat overheating and apparently solved it by flushing his engines for awhile. Thus I put together a simple gauge to attach to the flush port and headed to the river. The outcome surprised me.
A few years ago I had a cooling problem that resulted in me tearing portions of the engine and exhaust apart. After examining how very little sediment and corrosion there was, I concluded that flushing your engines was not that important. Bear in mind I only boat in fresh water. I incorrectly figured that you are running relatively clean water through the engine at high pressure all the time so it would always stay uncontaminated. These results will have me flushing more often.
These tests were done on the starboard MR-1 engine of a 2008 Yamaha 212X with about 410 hours. Connection was done at the port using the flushing hose. Note that during the test there was an occasional drip of water from the port. The air was purged all the way to the gauge. Temperature was about 80 F. RPMs were held until data stabilized.
My daughter drove while I held the gauge and took pictures. I had her run at specific RPMs to record what the PSI of the cooling water would be. See below.
