Pokeyt
- SX
My main question - Why is my drive shaft not engaging with the splines in the coupler? Is it possible somehow its getting blocked from engaging the splines?
Mechanic was doing some work for me before the start of our boating season up here in the PNW. He let me know that he could not get the jet pump unit reinstalled, the shaft was getting stopped about ~1.5” from being fully seated. His diagnosis was bad coupler bearing. I checked the tunnel and could see all the way to the splines in the coupler, they all look to be in tact and i didn’t pull any metal out when I cleaned it out.
Today I pulled the coupler and the bearing is definitely bad, I’m ordering parts and will get it all pressed together at a local shop. But even after pulling the coupler and inserting the drive shaft into it I’m still not getting any engagement from the splines. Surely this isn’t all the bearing right? I even verified that the issue isn’t with the shaft by inserting the port shaft and had the same issue, so this is definitely something with the coupler.
Assume at this point I’m replacing the bearing, the shaft coupler & the rubber shaft coupling.
