    With a Maximum discount of 35% this is the highest discount you can get on these, so don't miss out!
Crack in fiberglass/gel coat at seam in engine compartment
Kayno
Hi guys,
I am new here and just bought a used 2009 ar230.
I know this topic was covered by Eric popper and glassman.
I had the the same issue as I noticed a crack in gel coat along seam in forward transom meets floor of the compartment in engine bay. Behind rear seat.
But my question is, can this also happen directly to the seam opposite from that one? (Where exhausts exits)
And is this something to be concerned about?
Here are some pictures :
First two pics are in engine bay closest to rear seats
last 3 are from side directly opposite from this seam
thanks for you help and comments!
