cep022
- Acworth, Georgia
- SX
On a 2012 SX240 / Similar models the Cruise assist switch. Anyone know a none factory switch brand/part. I think it is a Double Pole, Double Throw momentary switch. Just and to confirm that. Having an issue when using the cruise assist sometimes the starboard engine does not respond to it. Then after a bit of running and or if you reach under and giggle things it starts working just fine. I'd rather just try replacing the switch before dropping 175+ for the switch and cables.
Open for any suggestions if anyone has any other ideas.
Part information (OEM) below.
Yamaha OEM - F2D-U8090-00-00
Yamaha F2D-U8090-00-00 Switch Assembly; F2DU80900000
www.partspak.com
