Brian Filas
- Richmond, VA
- FSH Deluxe
One of the benefits of having a FSH is it fits in a standard garage (well almost if you don't count the seat back). However, due to the minimal clearance between the console and the garage door means you really can't mount anything on top (like the cool organizer from Jet Boat Pilot). Until now...
I am building a custom dash unit that can be easily installed and removed each time you want to go out. It uses a piece of custom cut 3/4 starboard. I then attach all of my accessories (cup holders, electronics, etc.) to the starboard. Then the starboard is simply attached to the console using two kayak mounting rails and four quick connects. Just slide the unit on when you get to the lake and tighten. When you get home, loosen the quick connects and slide the whole unit off. This way my console only has a few holes (to attach the rails and for the electronic wires) and the unit is easily removed, but securely fastened. The rails essentially sit flush with the front lip of the console so no issues with the garage clearance.
I did a mock up of the unit first. Then designed the final version using SketchUp. I exported the CNC code and have Boat Outfitters pricing the unit right now (should take 4-5 days to get it cut and installed).
A couple of highlights. The tough part of the design is the console is not square (1/2 inch difference in width between front and back). This design accounts for that small change and should match the contours of the console. I also have routed two 4x6 rectangles down by 3/8 (half the depth of the material). These are just for phones, keys, etc. so they don't slide off. I also plan to mount two YakAttak cup holders that can hold a Yeti rambler. All edges will be rounded over by 1/8. The cut out in the middle is to run the cords up to my electronics (Carbon 9).
I will post more pictures once I get the final piece cut and installed. Tried to do it by hand but looks like total CRAP (you cant keep your lines straight doing it free hand). You really need a CNC machine to get a nice factory look. At one point, the 1/4 bit on my router broke (lucky I wasn't hurt). Once I confirm the cut is accurate, you should just be able to order the part from the shop. I will post the details once I have them.
In the meantime, here are some proof of concept pictures. Note that the rails are not attached yet and I haven't drilled my center hole for my power/ducer wires. I also haven't mounted the cup holders or the electronics (they are just sitting on top) and they cubbies are not routed into this design (I started with 1/2 board but realized it wasn't thick enough).
Let me know what you guys think or if there are any other design suggestions. I still have time to change my design. A few things come to mind. Like water collecting in the cubbies. Could just drill a couple of drain holes. Could also slope it slightly (towards the middle) and put the drain holes on the edge.
