Likely the same as the 2017 boats in which case is a single piezo beeper for all warnings (engine, depth,etc) and no volume. I put two layers of black electrical tape over the beeper and it is now much more tolerable.
Don't see a way to change the alarm volume, maybe try changing the depth: Press M and T at the same time, select 1 or water depth and press M to decrease or T to increase, then press M and T at the same time should return you to the Water depth, wait 8 seconds and you should be back to the main menu.
I think @Mainah makes a little mod to quieten it down. Or you could just tape it or use foam like @ttzz mentioned. You'd have to access the rear of the helm by removing the front starboard backrest/cushion.
