Different product to clean vinyl seats
Did you have any luck with this Thailand product?
Negative.
I would use Simple Green cleaner if must use a cleaner.
I use 303 Aerospace Protectant (not their cleaner which is crap) all the time, saturating the vinyl. I buy it by a gallon and use as much as 32oz, in one session, to go over the entire boat interior. Keeps it in good shape, and gets most stains and dirt off over time.
Thanks for the info. My cushions are starting to yellow in some corners, would Simple Green be the best for that? I'm going to start with 303 tomorrow!
Simple Green is just about the most effective cleaner I wouldn't be afraid to use on vinyl, but I don't know if anything without some sort of oxidizer would remove yellowing marks. Bleach/oxy will damage the seams though...
Well, gearing up for boating season here and I still have this seat pinking issue. The pinkish staining is around the edges of my most occupied seats.
After scouring the internet, It seems the consensus is that this happens from spray on sun block that contains PABA. That ingredient (para-aminobenzoic acid), mixed with water and a food source creates a bacteria. When that bacteria dies it leaves a pink stain in the vinyl, known as pinking. This is apparently common on the east coast and in areas with high humidity.
I've heard of people having success with OXY10 acne cream and magic erasers.
The service tech at my Yamaha dealer said he's been using a 50/50 mix of bleach and water once a year since 2008 on his 230 with no problems. When I asked him about the stitching, he said that Yamaha uses nylon thread which the bleach doesn't effect. I'm not sure that I buy that. I also spoke with a marine vinyl shop and they suggested Tilex!
I will try a few things and let you know if I find a cure!
Magic Erasers are usually frowned upon on a lot of boat forums and social groups i read. They are an abrasive pad and apparently some threads do not like it and it accelerates deterioration. Lots of debates and info on it so feel free to search up.
Check out this explanation: Pink Stains on Vinyl: A Problem | Ultra-Fresh Antimicrobial Additives.
