F.M.
- Decatur, AL
- 255XD
I've searched but haven't found any threads covering this issue.
On my 2017 Shoreland'r trailer, my right side taillight is a little weird. The running light works fine, but the brake/stop light and the turn signal are very dim. You can see the light getting brighter when signaling or depressing the brake pedal, but just ever so slightly. I've had 2 people flag me down to let me know it's out, but if you stare at it you can see it faintly getting brighter.
Any ideas on where I should start looking?
I've checked the 7 pin connection at the truck to make sure contacts are clean. And the trailer seems to be grounded properly. I'm thinking it might be a bad driver on the LED itself and I might just need to replace the light.
