Babin Farms
- Lower Alabama
Think about it this way with the Gel coat repair on the keel. It's towards the rear where no one can see unless your under the boat so as long as the repair is a close match I'd call it good enough, slap a keel guard over it and call it good. The longest I seen for guards was 14' so you can run a second one if you want to go all the way to the transom of the boat and seal the seam with some 5200 or epoxy & there again, it's going to be where you can't see unless your laying under the boat.
