DIY Boat Lift
chileanJK
AR192
I so fu... happy!!!
I built a boat lift, bought a car scissor lift for cheap and repourposed one of the lift (it has two) as a boat lift, put a remote control on it and this weekend tested it with the 190 and worked wonderful!!
This is when I bought the lift:
then working on the structure and hydraulics:
WhatsApp Image 2025-02-24 at 11.52.13 (2).jpegWhatsApp Image 2025-02-24 at 11.52.13 (1).jpeg
In position in the dock at the lake, I had to built a raft to move it:
Final result:
WhatsApp Image 2025-02-24 at 11.53.00.jpegWhatsApp Image 2025-02-24 at 11.52.50.jpeg
That's steel right? Or mixture of steel of the lift and aluminum for your add-ons? Or galvanized?
Is that salt water as well?
Nice work, I will be waiting for the second year report. Be happy you are not in our climate, that would be a tough one to pull out every fall and put in every spring.
The lift is steel and the add-ons are galvanized, it is a lake so not salt water, and there is a damp that release water in winter so april to september is almost dry, may be on winter I dissasemble the steel parts to galvanize them.
