What tires did you end up with?I have been through too many sets of tires in 4.5 years (I think 3), not to rotate also dropped the bias ply in favor of the steel belted and I think that was a good move. Showing no signs of wear like the bias used to. I got that tip from this forum.
I have been diligent about rotating my trailer tires at points in my life and other times I haven't done it for years. I have been towing all types of trailers for about 50 years. This includes small two wheel utility trailers, 5th wheel trailers goosneck trailers and too many other types to list. I had a ranch for about 30 years so the trailers were used daily in one form or another. I don't think that I have ever been able to document that rotating the tires made a difference. I can say that I have had less problems when I use tires that are made for trailers vs. using automobile or truck tires. Most people will never put enough miles on their boat trailers to begin to wear them out. They will need to be replaced due to dry rot or aging long before the tread is gone. The bearing repack/rebuild is far more important than the tire rotation.25+ years of towing trailers (not specifically boats though, but twin axle and one axle with brakes, the other not) - we rotated side to side and brake to non-brake axle every year with bearing repack/rebuild. Will continue to do the same on the boat trailer.
