Door warped?
ryanotown22
Think this is a warranty issue? Both my doors are not flat and flair out towards the bottom boat has 10 hours on it.
Dixemon
Low Country Ga.
I think anything cosmetic is within 1 year. those part were probably sitting in a stack in the wearehouse, im sure they were installed warrped. if you really wanted you could take them off and lay them on something smooth and solid, then add something heavy evenly to the surface. It will probably straigten out on its own in a few days out in the heat.
adrianp89
Tampa Bay, FL
252SE
Is the door warped, or are you missing the pin to hold it in place?
jmargo
Check that it is not sticking on the bottom sill. If so a quick light sanding to the bottom of the door should take care of it. Go the warranty route first,
