Swimmingly
- Falls Lake, North Carolina
- FSH Sport
The trailer in question is my new FSH Sport, which I'll be hauling home soon. Any 19' jet boat trailer should be very close to the same ideal height (measured at the base of the trailer ball opening, from the ground).
I still need to buy a drop hitch for my Jeep Wrangler. The base (bottom of the 2" square opening) of my hitch is at 23" off the ground. My trailer, without a vehicle attached, and sitting at the dealer, looked almost level at the base of the ball/tongue, which I cranked down to 18" off the ground-maybe a little too high. Those measurements should mean I need a 5" drop hitch, but I'm hoping another Jeep owner, with a 19' jet boat, can chime in and confirm for me.
Your Wrangler doesn't have to have a lift because I can add or subtract the 3" of lift from my own measurements (23"). I'm kinda picky about my trailer (and the tongue weight) sitting just right on the ball. Between the unlevel ground at my dealership and not actually having a vehicle attached to the trailer, it's not real obvious if the trailer height should be at 16" or 18" off the ground (measured at the base of the trailer, where the ball is secured).
I'll add that I prefer not to get an adjustable height drophitch because they're usually about 3x heavier than a dedicated-sized hitch has to be and also because one solid piece of gear is usually better than something consisting of three or four pieces/sections (the adjustable hitches).
Thanks in advance.
Thanks in advance.
