drjames1107
 - Lake Houston
 - Limited S
I asked this Question on the other Forum but nobody answered, maybe I will have better luck here?
Ok so I never asked this question because I just assumed it was not a problem. But I just looked at another boat and its different. SO here is whats happening. ( and this also is what was going on before my battery add/mod so its not something i did ).
ok so I have a 2013 242LS which comes with the factory DVSR and two batteries ( i have 3 now ). When I get back from a day of boating I hook up an very nice automatic charger(its no cheapie so thats not the problem). No matter which battery I hook it up to first the DVSR light comes on, after charging that battery to full I usually switch to another battery and so on. I leave all 3 switches in the off position
When I'm all done i unhook the charger and the DVSR light stays on and it will stay on for days. The only way to get it to turn off is to start the engine for a minute and start the stereo for a minute. Then the light turns off.
The light was just on for 5 days so I went out and tested the batteries and all were 12.64, 12.64 and 12.61 volts so it does not seem like I am getting a draw the stereo worked fine and boat started right up. Any clues to this, or do I have nothing to worry about??
**ok I did make 1 small change I moved the black DVSR wire from the start battery to the House battery because I was told that was the correct hookup.
Please Help!
Please Help!
