Engine Bay Wet Foam
Winerocks
Bloomington, Indiana
HO Impulse
I’ve got extra time on my hands for the first time....ever. Great time to tackle some of the little details that Scarab missed. Love the boat, and I don’t know that I’d trade it for anything else; but there are things that could have been done better. Every time that it rains, covered or not, there is water accumulation in the foam above the engine bay, on the bottom side of the hatch. I’m guessing there is no sealant in the holes where the seats are bolted on.
Anyone experiencing the same thing and have a fix?
Also, water accumulates in the channel that surrounds the engine hatch, and eventually overflows onto the battery and other electrical things. The fix for this is drilling a hole and installing a drain and tube to the bilge. Anyone tackle that?
Thanks in advance for your wisdom.
Scarab 215
DFW , TX
Same annoyances here, have not tackled either one of those as of yet. Looking for ideas.
Winerocks
HO Impulse
Well, I tackled the wet foam issue, which I believe is a result of the water pooling in the channels around the engine cover.
You can see that the foam overlaps and hangs in the water channel. Water runs to this area from the side bench seats as well as the rear seats. The foam sucks up the water.
I made a couple of stainless drains to deliver all this water to the bilge. The drains are made out of some 304 stainless bits I had kicking around, press-fit then spot welded with my TIG welder. The water channel is curved, so I had to go with pretty small drains. The stainless tube is 3/8 ID. I drilled the holes and attached the drains with 5200 (black was all I had). Tygon tubes will go on after the adhesive has cured. I’ll follow and let you guys know if it keeps things dry.
581F6BF0-C275-4CBA-98AB-13BCC1D893EC.jpeg022F1560-034F-4515-A44E-82F536D577F6.jpeg5F554D4D-D8F2-4292-AA0C-E0A1A368DF3E.jpegF3F4ED16-810A-4BFA-956E-8AF9D3E50230.jpeg75B1671B-A961-477F-8DA9-19D8AF5EFA00.jpeg924182F8-2897-4A71-8060-61BAB1921219.jpeg
Scarab 215
DFW , TX
View attachment 117724View attachment 117725View attachment 117727View attachment 117726View attachment 117728View attachment 117729
Nice Job! Thanks for Sharing!
Winerocks
HO Impulse
We’ve had some heavy rains, and my little drains are working as planned. The engine-bay foam is almost completely dry now. The drains would have been more effective if the were flush (I knew this would be the case), but what was a channel full of water is now a few drops.
One less annoyance!C54A6004-EE9C-4DC2-BE46-D9059BC42323.jpegC54A6004-EE9C-4DC2-BE46-D9059BC42323.jpeg
RightStuff
Twin Cities, Minnesota
Moomba
Scarab 215
DFW , TX
One less annoyance!View attachment 118730View attachment 118730
Thank you for the update!!
Winerocks
HO Impulse
Same annoyance on my Yamaha so I did something similar, but I found some plastic drains online (lots of searching to find the right size!). They have worked great draining all those little gutters around the boat.
Here's my post on it for reference: https://jetboaters.net/threads/the-official-what-did-you-do-to-your-jet-boat-today-thread.2661/post-404686
Ha! Thanks for the link. I knew there had to be something out there. I searched all over google, and couldn’t find anything. They’re cheap too.
