jetexpress
- Pataskala,Ohio
- SX
Took the family to Smith Mountain Lake in Virginia for vacation this week. On Monday we rode about 30 miles at 7500 rpms most of the trip. Boat ran great with no alarms. Our boat is a 2005 SX230. Maxes out at 10,200 rpms. On Tuesday we went out to go tubing. After about ten minutes of driving, we heard a loud bang. Port engine ran rough than shut down. Checked the man holes hoping to find something stuck in jet prop. Nothing. Stomach started to get that bad feeling that something catastrophic happened to engine. Confirmed that feeling when I opened the engine hatch and saw oil in the center sump and shrapnel all around engine bay. Thankfully the engine hatch contained the shrapnel. Made it back to the dock on one engine. Tried to take pictures of the engine, on the bottom side where it hatched open. The crank case blew open under the third connecting rod and crank shaft I believe. I don't see any internal parts protruding through the block. Do you guys think gas could have gotten by the piston rings, into the crank case, and eventually ignited, grenading the engine. Not an expert on engines. Any thoughts or opinions are appreciated. The pictures are the best I can get since it's from the bottom side of the engine and I can't see what I'm taking pictures of.
