Mikeybagzz94
I own a 2013 Yamaha 242 limited S, this year I found two engine codes that I was able to clear by fixing some exhaust issues and replacing an o2 sensor. When I now turn on the boat and check the engine diag via the tachometer all the codes have cleared but now I’m left with a code (Normal Spn 0). Does this mean that there is no more problems and will this clear on its own?
Can you tell me if you ever got an answer to your question about the Normal SPN 0 code?
I'm bringing this post back from the dead as I've searched and don't see any answers out there. Has anyone ever got an answer on the Normal SPN 0 code?
In my case, I got a bad O2 sensor code. I changed the O2 sensor, and now I have the Normal SPN 0 code, and can't seem to clear it. I don't want to drop $150 at the mechanic for him to plug in a laptop for 1 minute to clear it. Let me know!
