Engine flush inlet hose adapter leaking?
RobertH
Sugar Sand
Tango Xtreme
Hi guys,
I have the Sugar Sand Tango, and noticed that when in the water with the engine running, the engine flush hose inlet port leaks water out, dribbling salty water down from the top of the engine, which definitely isn't great. Obviously water is only supposed to go in, not come back out from here.
Does anyone know what that part is called, where to source a replacement and how to fit it safely?
This is a screenshot from Crowley Marine showing the flush adapter parts. Looks like everything is still available. This is for my 03 240 but they should all be the same.
Thank you - I'll take a look
Hi Bilmon,
Thank you for the pointer. I've checked my engine bay, and the Crowley Marine site, and am wondering if I am missing some end pieces to this hose that may be causing the leak ? Here's what I have on hand (photos) vs what's shown on the Crowley site.
Can I just plug the end with like a regular garden hose adapter or something ?
Thanks !!!
Thanks for your post. My boat just has a standard garden hose attachment on it taking the place of parts 45-51. I to have water coming out when running the engine. I was going to put a tap on it to stop the flow, so I can turn it when flushing the engine and turn it to off when running the engine. Im not sure if this will effect anything if anyone can tell me?
Hi Bilmon,
Thanks !!!
I have the same problem. A garden hose attachment will leak still as that's what I have at the moment Pre-existing). I am going to get an inline tap with the garden hose attachment. I hope it will be fine. Please advise otherwise.
