Engine refusing to start
Sulaiman
Hello everyone
My name is Sulaiman from Saudi Arabia
I'm the owner of 2015 Yamaha Ar192
I got a trash bag stock inside the engine fan
After I removed the bottom cover and removed the bag the boat don't give me any spark even though the battery is new
Kindly can someone enlighten me why is the engine not tuning on?
Thank you
Those two events are unrelated. Other than the potential of the cleanout kill switch.
Since you had something stuck, there is a chance you opened up the back cleanout tray to pull the cleanout plug and discover the bag. That plug needs to be reseated properly, and the door closed to fire the engine. There is a chance the door is not closed fully, or the kill switch on that door is not depressed properly. There is a chance the switch is damaged too.
Good luck
