BigN8
- Corinth, TX
- SX
Weird occurance today. Floated for about 3 hours no stereo. When I started the port engine the battery seemed dead, engine turned over sluggish. Then started stbd. Same thing. As soon as stbd cranked the port engine started shuttering and make a knocking noise. Check engine alarm came on. I shut both down. Check engines. Nothing seemed wrong. Then I started stbd first then port. Same thing sluggish start but this time stbd shuttered and made weird sound followed by check engine light. So I shut stbd down and started to lp back on port since it was running fine. Just for the heck of it I tried restarting stbd after about 1 minute. Started fine and ran fine. Tried cruising at 30 mph no problem. So I let it idle for about 20 minutes while I removed the bow ladder. I started thinking I've got a bad battery and the low voltage start some how messed up the engine on start. I shut down engines and then switched battery selector to 1&2. Then cranked both engines. Both started perfect with no lag in cranking and no engine alarm.
