3 green tornados
- Southern CA
- 212X
I just bought a 2015 212x w/ 35.4 hours on port motor and 34.7 on starboard motor. It still has two months left on factory warranty.
Back story:
Started both motors at home waiting about 5-10 seconds before turning on the water. Things went great. Turned off the water after about 2 minutes then the motors about 5 seconds later. Then drove 7 hours through the desert with my amazing wife, 5 kids and two dogs.
Launched at about 8:30pm.
boat was floating but still tethered to the trail when I started both motors. They idled fine and water was coming out the side ports.
I disconnected the the trailer strap and jumped in with my boys from the bow as my wife pulled the motorhome and trailer to our spot.
Shortly after turning the boat at virtually idle speed the starboard motor “sputtered” and rpm jumped and fell a couple hundred rpm then smoothed out as I slowly throttled up to 3-5mph and the starboard engine alarm starts and a flashing check engine sign. Seemed like just a second later the motor died.
I turned it off and continued around the jetty as slow as I could possibly go because I was worried about 1. Hitting something with the three boys in the bow and 2. Forcing water into the starboard engine.
this morning I have checked:
electrical connections all seemed tight and good. Battery voltage was 12.49 and virtually no resistance across terminal connections.
Checked clean out hatch switches and seemed like the were positioned correctly as I can tell.
Checked kill switch
Ensured throttle was in neutral.
both engines start this morning but starboard motor check engine light is still on and sounds an alarm before it dies.
Port engine is starting fine and seems fine at idle.
Can’t take it in for almost a month as all dealers are super busy now at the start of the season.
any ideas?
Back story:
Checked kill switch
any ideas?
