VitaminSea
- Central FL
- 252SD
Hey braintrust, need some guidance here..
2012 SX210 with the MR1 motors.
Been trying to solve for an engine overheat alarm for the last few months on my port engine
Have replaced the following-
Engine Temp Sensor
Thermo switch, both engine and exhaust
And have swapped the intake sensor between the motors.
Also just had the motor pulled and water jackets cleaned to rule out blockage (that was when the issue was intermittent after replacing the sensors).
Initially the issue was intermittent, however it’s now persistent on the YDS, as in clear it and it pops right back up.
Just floating, engines off - the YDS was bouncing around with readings between 90C and 106C. YDS indicates the fault as Irregular.
Any suggestions on what to check/how to problem solve for this? The sensor is somewhat or a pain to get to as it’s in the block under the headers, else I would try to swamp them now (on the lake at the moment).
Engine Temp Sensor
