Engine won't crank. Hear clicking sound and wonder if i have a bad relay
lukan734
Engine wont start. Hearing clicking noise when key turn. Ar190 2023
Acard7
SW Iowa
Try jumping it at the solenoid.
lukan734
I upload a video wonder if you see it, i'm new to the forum
Acard7
SW Iowa
Your boat is fairly new, I bet you have a dead battery. Charge the battery and make sure the connections are proper and tight.
Dave burke
Near Lake Placid
I'd start with the battery, make sure it produces at least 12 volts, ideally 12.5+. If the battery is good, check all your connections to the battery. If that doesn't work, jump the solenoid as @Acard7 suggests. Usually a clicking sound is a bad solenoid in my experience but it's hard to believe the solenoid is bad on a new boat
David Martin
Punta Gorda
You should test solenoid I use a remote starter switch.............Some do a screw driver across the 2 bolts to turn over the started I just hate the arching sparks like I welding something. If engine turns over using remote then starter and solenoid are fine......move on to relay and loose or corroded wires both could cause a no turn over/clicking problem.........I always look for a bad ground first boats have this problem most often. Also look at all contacts on the battery switch. A bad ground or positive wire cant handle the 100amp the starting is asking for...... so it clicks.
A bad starter relay that is bad cant hold in.......... so it clicks like others have said to.
