Exhaust
Dan Hops
Kingston, Ontario
Scarab
HO Impulse
Can anyone with a 2014 195 HO Impulse help me out. I need a picture of the exhaust output pipe just below the ladder like the pic below. If anyone could post one here or email me at hops08@hotmail.com it would be a huge help.
Here is mine.
Also @Dan Hops , and its completely unrelated. Looking at your picture, you are starting to get corrosion on your jet drive. You can see it on your housing, and starting to take on the housing bracket. Take a tooth brush with some CRC 656, and brush it off. Then give the whole assembly a nice bath in it. Look at mine. My boat has over 30 salt water hours, and I used to like by the beach. The CRC keeps that silicone nice and flexible, and keeps all your O rings, fasteners, linkages in tip top shape.
Anyway. Looks like my exhaust is in the same place yours is in.
thanksView attachment 25298
Hi Dan, do you keep your boat in the water ? is this little bit of corrosion from salt water or electrical current at your marina ? If neither,then what do you think is the source of corrosion ?
