Topper232
- Marlton, NJ
- Limited
So, when I was flushing the boat after the first run last weekend, I already had the clean-out hatch open from taking the plugs out. When I started the Starboard engine, it ran fine, when I went to start the Port engine, it wouldn't start. I quickly said, duh, the clean-out hatch is open. Then I realized that it was open the whole time that I flushed the Starboard engine. I closed the hatch, fired up the starboard engine (no water) and it ran, but when I opened the hatch, it kept running, so clearly it's not doing what's it's supposed to do.
Has anyone documented replacing these, or it's so easy that I should be able to figure it out once I'm in there?
Thanks
Thanks
