Finally had some heat soak.
4wheeldeal
Kingston Ontario
AR192
Finally got some heat soak, 7600 to 7200rpm after about 3 miles of wot. So going to toss in the svho intercooler in. Props to @SAGERFLY for the pipe and y pipe!
Question, no issues with running no collar for the ribbon delete? Don't have one yet, guess I should order one.
Mike
SamCF
Greenville, SC
SX192
I don't think there's a benefit to using the ribbon delete spacer.
haknslash
Lake Martin, AL
Moomba
Just don't leave or reinstall the rubber piece from the ribbon when you remove it.
Irvs
SX192
yeah, do as @haknslash says! ...or else you'll end up like me. I left mine in and it got sucked in and destroyed the head.
4wheeldeal
Kingston Ontario
AR192
Damn, that sucks. I'll be sure to remove it. I'll try it without the collar first might get one at some point we will see. Thanks for the tip.
I was actually amazed I got heat soak, I know it was was hot coming out of the pisser but seeing RPMs drop a bit was odd. Oh well the fix is coming. Just missed a big thunder storm so I was happy to make it back.
